am going to put the operating system on my aspire one 120gb , xp will my main OS with programs installed. and other OS will be used so i can familarise mytself with them
i am thinking in this order for my 120gb
1 ntfs 20gb xp pro
2 ext 5gb openseus
3 hts 15gb leapord but leapord uses 9gb am i right?
4 a 80gb data partition rest as fat32 data for compatibility
i wont be using linux/leapord extensively to install apps , but mainly as OS just to play about with . so trying to minimuse disk space but my main OS will be XP ; so i have some questions
1 = i still want to be able to write 4gb + data files , so am i better off using xp partition as ntfs or fat32 or use the data partition as ntfs but then linux/leapord cannot access it without kernal add on so i am in chkicken egg situ here. i think i will go for ntfs so i can still at least play with 4gb+ files and leave the data partition as fat32 for overall normal docuement data
2 opensu or ubuntu better? in terms of functionalily not just gui. i can program c++ , c , java so pretty competent using an OS if complex but neither do i want it DOS based. after researching the internet i will be going with openseus with kde as ubuntu i can still run off the cd
3 what order of OS do i install to get it tripe/dual boot - i am presuming xp , openseus and then leapord
4 what program do i use to fdisk , create the partitions ? - google shows each OS will recongise an exisiting OS is present and will allow new menu options for extra OSs ?
5 what program do i use to create the boot menu options for the different OS ? - again google shows that each OS will accomodate the menus
6 after all this hard work , i want to image this a bootable recovery CD. i am thinking to ghost it , but will ghost recnognise ext and hfs file system ,
and then once i get the GHO image , how do i get ghost to auto run this GHO file when booted from a DVD ? - i know how to make win98 boot disk on a CD , so i am presuming to stick GHOST.EXE on to it and the image file seperately . but i want to make it all more stream lined so how would i get GHOST to auto recognise to image the original image back over but with obviously a prompt of some sort
1 ntfs 20gb xp pro
2 ext 5gb openseus
