Triple 24" LCD Mount?
Loafdogg420
I have 3 24" Samsung LCDs (model listed in sig). I have a real nice desk that I'd like to keep but the 1st and 3rd displays are very close to taking a nose dive off the edges.
Does anyone have any experience with the triple mounts available from Planar (997-6035-00) or Ergo tech (100-D16-B03)? Those are the first two I found on Google but I haven't found any good reviews. I was thinking of rigging up some small extensions for the desk but would like to avoid that, if possible.
Both of those manufacturers' specs say that 24" is max supported size but, how much of a buffer do they have for different model displays?
Also, I am a bit of a newbie in the Eye-finity department.. How much of an angle should I set my outer monitors at? Is that basically preference or dependent on the displays?
Any help is greatly appreciated, thanks in advance.
The Ero Tech is great, its been talked about a lot of places and the reviews are all positive, I'll be getting one this month.
I've got the triple arm mount from ergo*tech and I highly recommend it. Ive got 1.5 inches of rail left on each side and thats with my side monitors brought in about 40degrees. I think you could squeeze 25 inchers if you wanted to as long as you didn't have fat fat bezels. I got it from Fry's.
http://www.frys.com/product/5955874?site=sr:SEARCH:MAIN_RSLT_PG
Here's some pics for you to get an idea:
http://img340.imageshack.us/img340/4858/eyefinity.jpg[IMG]
[IMG]http://img801.imageshack.us/img801/2596/eyefinity2.jpg[IMG][/QUOTE]
Sweet Setup! How stable is that mount, looks like it would have alot of side to side wobble?
The stand is very stable and sturdy. Even if I pound on the desk, there is very little wobble. This is one of those purchases where I was very skeptical coming out of the store and ended up being being pleasantly surprised. I also forgot to tell the OP that I have 23" not 24s, but I still think he'd be ok. My NEC's are 21.5" wide including bezels.
