erek
- Dec 19, 2005
Spyware craft is interesting, from NSO Group's Pegasus to Candiru
"Kaspersky’s summary of the exploit chain is:
Advertisement
https://arstechnica.com/security/20...on-campaign-targeted-secret-hardware-feature/
Wednesday’s presentation, titled What You Get When You Attack iPhones of Researchers, is a further reminder that even in the face of innovative defenses like the one protecting the iPhone kernel, ever more sophisticated attacks continue to find ways to defeat them.
- Attackers send a malicious iMessage attachment, which is processed by the application without showing any signs to the user
- This attachment exploits vulnerability CVE-2023-41990 in the undocumented, Apple-only TrueType font instruction ADJUST for a remote code execution. This instruction existed since the early 90’s and the patch removed it.
- It uses return/jump oriented programming, multiple stages written in NSExpression/NSPredicate query language, patching JavaScriptCore library environment to execute a privilege escalation exploit written in JavaScript.
- This JavaScript exploit is obfuscated to make it completely unreadable and to minimize its size. Still it has around 11000 lines of code which are mainly dedicated to JavaScriptCore and kernel memory parsing and manipulation.
- It’s exploited JavaScriptCore’s debugging feature DollarVM ($vm) to get the ability to manipulate JavaScriptCore’s memory from the script and execute native API functions.
- It was designed to support old and new iPhones and included a Pointer Authentication Code (PAC) bypass for exploitation of newer models.
- It used an integer overflow vulnerability CVE-2023-32434 in the XNU’s memory mapping syscalls (mach_make_memory_entry and vm_map) to get read/write access to [the] whole physical memory of the device from the user level.
- It uses hardware memory-mapped I/O (MMIO) registers to bypass Page Protection Layer (PPL). This was mitigated as CVE-2023-38606.
- After exploiting all the vulnerabilities, the JavaScript exploit can do whatever it wants to the device and run spyware, but attackers chose to: a) launch the imagent process and inject a payload that cleans the exploitation artifacts from the device; b) run the Safari process in invisible mode and forward it to the web page with the next stage.
- Web page has the script that verifies the victim and, if the checks pass, it receives the next stage—the Safari exploit.
- Safari exploit uses vulnerability CVE-2023-32435 to execute a shellcode.
- Shellcode executes another kernel exploit in the form of mach object file. It uses the same vulnerabilities CVE-2023-32434 and CVE-2023-38606, it’s also massive in size and functionality, but it is completely different from the kernel exploit written in JavaScript. Only some parts related to exploitation of the above-mentioned vulnerabilities are the same. Still most of its code is also dedicated to the parsing and manipulation of the kernel memory. It has various post-exploitation utilities, which are mostly unused.
- Exploit gets root privileges and proceeds to execute other stages responsible for loading of spyware. We already covered these stages in our previous posts.
Advertisement
![1703711603580.png 1703711603580.png](https://cdn.hardforum.com/data/attachment-files/2023/12/956608_1703711603580.png)
