Tools for cutting case grills
n0lram
can anyone recommend any tools for specifly cutting the grills out of a case... some links would be extremely helpful. thanks!
by "cutting the grills out of a case" do you mean removing a preexisting grill on a case, such as the pre-cut out ones that reduce airflow a lot?
if not please clarify, as it is somewhat unclear what specifically you are talking about.
methinks youre in the wrong forum :p
you can use a dremel, tin snips, anything that will cut metal works fine
