Okay I know that this has been asked and asked but I was wondering what most of you guys think.
I recently built a system for a person who is not lets just say a pc person. She mostly surfs the net and wants to burn CDs/DVDs.
Okay so I put her together a Celeron D 326 and an Intel 915GAV ATX Mobo.
If it was my board I would usually flash it because force of habit and I usually install a floppy drive again out of force of habit.
This Intel Board came with a January BIOS, and several new BIOS's have been released since then.
She also stated she did not want a floppy drive so unless I dig up one or take on out of my system. So I'm stuck with either not flashing, flashing in windows, or flashing with a CD if its possible.
Okay I have only flashed with floppies before, and I am weary of flashing in windows.
I have ran the system for about 12 hours testing temps, memory, and just generally messing around with it, and I have suffered no BSOD's thankfully. Also I just put in a brand new CMOS battery just to make sure I cover all my bases.
So what do you guys think,
1) Should I leave the BIOS as is (following the ideaology if it is not broke do not fix it) should this be okay and do you guys usually flash to the most recent BIOS for friends and clients you build for as just a standard.
2) Flash with Windows (Is really as safe as the manufacturer's make it sound)
3) Find a floppy drive and flash with a floppy
4) Flash using DOS but with a CD instead (is this possible)
Thanks again for all your advice.
