tips for acrylic?
poddo
2005 [H]orde|Bowl Champion
Hi all. I've never modded a case before, so for my new comptuer that im building, i jsut wanted to start out with a sweet case. I'm looking at going for clear acrylic. Can anyone recomend a nice one? I've heard the lack of MOBO tray can be a real pain. Do any of them have trays? And lastly, does anyone have any tips for keeping them nice and clean? dust is my main worry. And getting the wiring to look nice. Thanks for any help!
A Great clearcase can be found HERE as far as dust use filtered grills on your intakes also found HERE An example of a loaded clear case can be seen HERE
Thanks. does anyone have any sites with wiring guides? And would you recomend a clear case? Or should I go with a normal case with a huge side window?
i am not a fan of clear cases because its almost impossible to hide your wires. in regular cases, you can put it behind mobo tray, between drives, etc. in clear case all of those will be visible. just get a nice case with a window and mod your own window
True, a clear case is like going jogging naked. All your assets as well as liabilities are ther to be seen!!!
Lol, thanks for the advice. I'll look into it, still not sure.
I like building my own acrylic cases from scratch. not a kit. but a fine tooth say blade and a router does the trick for me
i like clear cases when they are painted, there was a guy on here that had a crazy paint scheme on a clear case..it rocked
