Hey all, hows it goin? I have an MSI Geforce 4 Ti4200 graphics card(128 meg) and it's stock speeds are 250/446 MHz, I've overclocked it to 300/605 MHZ with the addition of a ThermalTake Copper cooler and RAM sinks, is there anything else i can do to OC it even higher while keeping it running good, or is it pretty much maxed out now? Any answers are apreciated
. Heat doesnt seem to be a major issue, the standard temp of my card was like 39 degrees celsius (with standard cooler) and now its around 40 full load, and the ambient temp in the case is usually 20-25 degrees. Games just start to run and look bad at higher speeds than 300/605. Is this a voltage problem or what?
