also if the drive came out it would be bad.
How so?
The swap file was not made to put on a temp/removable storage device. If the device was to be removed Windows would more then likely error or even blue screen. I have also seen where some people have reported hangs and pausing when they moved the swap file to a USB flash drive. I am not sure if this was due to the flash drives speed, or other factors, but it has been reported.
I tried it out and never got any error or blue screen. I agree it's not a good idea to do this either way but while just to see if it worked or not I had 0 issues.
mmm, are you sure you moved it to just the usb stick only or added a second location?
yes, but you are severly going to shorten the life of the usb-stick
They have an EXTREAMLY low write count
Q: Won't this wear out the drive?
A: Nope. We're aware of the lifecycle issues with flash drives and are smart about how and when we do our writes to the device. Our research shows that we will get at least 10+ years out of flash devices that we support.
Uhhmmm... this is a falacy. If it wasn't, why would Vista be using Flash-RAM based products for ReadyBoost?
