Great site I've enjoyed reading through quite a few reviews, it seems yall really put the products through the ringer. That being said, I do have a few questions that have seemed to linger a bit. I've heard 2 schools of thought when it comes to buying power supplies A. Buy for efficiency, i.e. find what your rig uses on average and buy a unit that will be the most efficient or B. Buy a much larger power supply than what you need so your psu will not work as hard theoretically extending its life. I've always tended to purchase PSUs with first school of thought while also having a little extra wiggle room later for expansion. But the second school of thought seems viable as well. Less stress on a unit, longer life. Arguably the second option is more expensive though as you are buying way more than what you need. What are your thoughts on this?
Case in point:
I have a build I putting together for my younger siblings.
I almost have all the parts for the following build except for a PSU. https://pchound.com/X3uv7c/ What wattage would you comfortably recommend? My initial thoughts were somewhere around 500. I wanted to build a little extra room in there if I were to put another 970. Right now I'm leaning with XFX XTR 650 or a EVGA GS 650. Not too sure. If I did decide to OC the CPU how much would that increase the wattage?
Thanks in advance for a little clarity in this matter.
Case in point:
