Think it would be hard?
altec
To setup like 4 pci not pci-e video cards with two monitors each (8 total).
No it's quite simple. Just plug them in and go. Windows XP supports up to 9 monitors IIRC.
You have Ati 9200 PCI cards with 128 MB that don't cost so much. Plug 4 cards and You will have 8 monitors.
MD
Now i need 6 monitors and four cards lol.
EDIT,
I have two setup right know.
EDIT2,
I remember some were seeing video cards with four vga slots?
Yeah its kinda easy, to make it painless, try to stay with the same manufacturer. Although I used to use an ATI AGP card and a NV PCI card for 3 monitors.
No, once i set the PCI card as secondary, I just left it alone. I didn't install detonators or anything for the NV card, I just used the INF file in XP.
when you get all those monitors you should hook 2 of them up ( the ones in the middle near your face) up to an agp video card so you can have some gaming too, or at least some acclerated Graphics :D
