Thermalright SP-97 help
anchor
Ok, I have the Thermalright SP-97 HS/Fan and I was wondering how to hook it up to the processor correctly, I have the DFI nforce2 Infinity Mobo.
I have both plates to put on back of motherboard, and both fit so im confused :\
If you have a link showing all the pictures, please paste.
Those are great heatsinks, I have the P4 version. One thing I would suggest is make sure your case airflow is good and that you have good exhaust to draw the hot air away from the SP-94. I need to replace the stock Antec fans I'm still using as exhaust because they don't move enough air to create a strong current.
What happens is my temps rise to around 42C, and stabilize for a bit, then start to climb again to around 44/45 C where they finally stop. (power supply temps follow a similar pattern).
