Thermal adhesive?
itsukisama
I still have the zalman heatsinks for my old vga cooling kit.. But I had to remove it from my old video card because I had to RMA it. Where can I find that thermal double sided sticky tape? I haven't had any clue where I can get it. :mad:
Another option is to put regular thermal paste over most of the chip, then just a tiny drop of superglue in the corners to hold the heatsink on. If you keep the drop small enough, you should be able to remove it fairly easily in the future too, but it'll stay held on for now.
