shadowlord
- Jan 6, 2005
Hi all!
it's spring/modding-time again !
i still had a mini itx mainboard laying around from my previous jukebox project so i thought about building a pc dedicated to websurfing and reading my mails.
since browsing the net is what i mostly do on the pc i see no need to start up the gaming rig, the 1ghz from the itx board will be enough.
the goals are:
nice looking (to be able to display it on the desk)
energy saving for daily operation
near silent operation
build the mdva i was given in the [H]-forum secret santa event a nice home. (Thanks again Arcygenical)
here is a shot of the mdva:
the case will be custom built from tintent plexiglass measuring only 200x200x200 mm
ok enough talk.... on with the pictures.
first i ordered the base and the top plexi plate to install the mobo and take the measurements for the cutouts i need on the back and front plate.
here is the rough layout:
i used a mini itx case to take the measurements needed to mount the mobo on its new home:
then i drilled the 4 mounting holes, the white tape is my depth gauge.
since the standard mobo stand-offs have a inch thread and i have only metric dies i needed to come up with a different solution.
i threaded the 4 holes with a M3 thread and made myself some 5mm spacers with my lathe:
and screwed the mobo to the base plate with M3 screws:
i have drawn a 1:1 sketch of the internal layout seen from the side, to help myself imaging how to mount things.
here you see the slimline dvd-writer and the 90mm exhaust fan on the sketch:
it looks like a 90mm exhaust fan will fit
i was drawing sketches for the plexiglass cutter for the side panels when i noticed that my ruler that i'm using was way off !
so i had to stop for today and will have to buy a better ruler tomorrow.
anyway i finished a mod on the keyboard for this project.
since i'm hesitant to use a kvm switch for my gaming rig and project silent surfer i bought a wireless set for silent surfer and a wired combo for the gaming rig.
to be able to remove the wired keyboard easily i shortened the connection cable and will connect it to a usb extension cable in the future.
thats all until i buy a better ruler and order the sidepanels so stay tuned !
the goals are:
