YeOldeStonecat
- Jul 19, 2004
I had previously locked down a terminal server, one of the settings was to disable the ability for RDC to "map" drives to it, from the client site within the RDC. So I yanked that GPO...just about all the settings reverted to normal...BUT...from the terminal server, if I go to it's settings the checkbox to put a check in to allow clients to map...is grayed out..and not avail. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Server 2k3.
Any ideas on how to force that feature back in?
Server 2k3.
