Tentative configuration
shadowbreaker513
I figure I can put a DFI motherboard on hold so I can get a new case and watercooling. I'm not especially knowledgable on watercooling parts, so advise me if I am missing something. This is mainly a configuration for price, ease of use/setting up, and so I know what I am doing. If there are better parts for the money, please tell me.
Case - Black Chenming 602 Case with window - $80
CPU Waterblock - Danger Den Maze 4 - $35
Resevoir - Danger Den 5.25" Polyethylene - $18
Tubing - Clear Flex 3/8" (10 feet?) - $11.20
Pump - Hydor L25 - $38
Radiator - Black Ice Micro II (This would mount on the back 2 80mm slots right?) - $55
Total - $237.20
Is this a good setup? Are things missing? Can I get a better one for my money? Will it cool well? Does it all work together well?
All have you have been a huge help in my questions about watercooling and I appreciate that. It's not often you find forum people so helpful and thorough.
I would personally change the case to something that would be easier to install a dual 120mm rad. I would also go for a MCP350 pump over that Hydor but it's twice as expensive. Otherwise, the setup looks good.
I was looking at things like that but I can't stomach the price. Especially with either my current psu or processor being dead.
shadowbreaker513 said:
I'm poor and don't have the money. Even this setup is stretching it.
For the ~$10 increase in price, you're telling me you couldn't skip lunch for a few days?
Seriously, the TDX/RBX smashes the Maze4 in performance
But to each his own I guess
If you're on such a tight budget, you'll probably get more performance for less money by just getting a nice system setup now. Then later when you have money you can make it better by watercooling it.
That may be the best idea yet.
But if you still wanna wc then maybe you need to look at a
Swiftech kit. And here's a list of sub $50 cases over at the Egg. Should still keep you in your budget.
Thanks for all your help. On a side note, does anybody know of any water cooling setups that would fit in a Monarch Hornet Pro? I've been debating whether to get that, or go large wwith watercooling.
