B
bostesseger69
Guest
First bear in mind this is my first WC setup.
Can someone tell me if this is to much? I'm idling at 50C load at about 60 or so on my q6600. Its not over clocked by much, only at 3.5 @ 1.4V, and I've got a stock settings 8800gts on the loop to.
I've got it set up like this. Pump, to resevoir, to radiator, then y split from radiator to gts and cpu, then y split back to pump.
Do I need to change the flow or try and reset the as5 on the cpu or what?
Thanks for the help ahead of time.
