I've got a 4850 with the stock heatsink fan on there. I had removed it at one point to try an aftermarket unit, but it wasn't cooling the memory well enough so I had to put the stock one back on. Ever since then, the card overheats so much in newer games that the PC shuts off due to internal protection against temperatures above 120C. No crashes or lockups anywhere else and no artifacting, ever.
I pegged the fan at 100%. I even tried turning the clocks down 150 MHz in ATI Tray Tools but eventually the temperature creeps up toward shutdown in most newer games. That seems fishy.
After a recent re-application I fired up the PC and arrived in Windows at 55C. Played a game up to about 80C, seemed great, powered down for a few minutes. Re-entered Windows at 80C. Tried a game and it gets to 115+ quickly. With the fan at 100%, it took 10 minutes to get the temperatures back to 80C. I put it back to auto and now with the fan at 50% it is slowly crawling back up to around 90C.
Could there be some internal damage here that guarantees thermal runaway? Maybe the heatsink isn't making contact with the die, but the thermal compound (I've tried Arctic Silver and some generic white paste) looks to be spread evenly and I carefully snugged the hardware in multiple attempts now.
