QFT its only good for comparisons like 'my temp rose 5 degrees'Top Nurse said:-20fWhy do you ask lemmy? Comparing your temps to someone else's temp is rather pointless due to the huge tolerance of hardware sensors on MB's and GPU's. If you change nothing at all and UG your BIOS you may see wildly different temps.
How do you figure that 25c is high................lemmy said:i'm just wondering cuz i put my cuplex xt, and i'm getting around 25 degrees celsius during idle times. This is in a room at around 80-85 degrees farenheit, i'll check the difference in temp in a room of 70 degrees farenheit. but 25 seems a bit high for me =/ i might try and redo the AS5. Wondering if i should just reclean it with a alcohol and qtips =/
are you running stock clock or did u OC?eumskickin said:i got 21c with room temp being 20c on my 3200
its always 0.5-1C over room temp
lemmy said:top nurse what was your room temperature with that 19C reading? and what clock was ur cpu at? mine was at default clock and running 25 C
lemmy said:how do u get -20F???? are u using vapochill or something? Anyways i went to my basement where it was about 74 F and i got 19C temps
Top Nurse said:"I was kidding..."![]()
Wildace said:my 3200+ runs rather cool with the stock hsf![]()
idle temps
Sensor Properties:
Sensor Type Winbond W83627THF (ISA 290h)
Temperatures:
Motherboard 25 °C (77 °F)
CPU 27 °C (81 °F)
Aux 19 °C (66 °F)
during prime 95, i cant get it to go above 32c/90f
TheRapture said:Your board is a liar. I bet you are at least 10c higher than it is reporting...lots of NF3's vary wildly in temps....and with the stock heatsink....you ain't running no 32c under load...![]()
