nobody_here
- Feb 1, 2006
wondering what everybody running Vista (i am running ultimate 64bit if that matters) is using to keep tabs of temps for the CPU when overclocking
thanks
thanks
well, i wish there was a way to not have to remember to hit F8 every time i boot up.....that sucks, but at least i have a way to make Core Temp work for now
You don't have to hit F8 every time. Core Temp works just fine under Vista 64 for me with driver signing disabled.
I've posted this before but I'll do it again.
The bcdedit commands must be run from an elevated administrator command prompt, followed by a reboot.
Bcdedit /set nointegritychecks ON
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
Make sure you don't have any of the following updates installed
KB932596
KB938979
KB938194
These all reinforce driver integrity checks.
This way, I can run ATi Tray Tools, Core Temp etc without needing to worry about unsigned drivers and remembering to hit F8 every time. And F8 doesn't even work if you've certain hotfixes installed.
You have the option to remove any installed updates. I can't particularly see a problem with allowing unsigned drivers to install as long as you're aware of what you're installing .
EVEREST Ultimate here.
