Temperates dont Seem Right
Carter54
I put together a new rig over the weekend any my temperatures seem off. I have 3 programs and the BIOS all telling me the same temps but they just done seem right.
Im using ASUS AI Booster and PC Probe 2 plus Speedfan 4.32.
it says my CPU temp is between 17-22C which seems low for a DC presler chip and my MB temp is 31-33C Plus speedfan is picking up some weird other stuff.
PC&
try all the mirrors not just the one closest to you, i had that problem. you can also take the file name your trying to download ( biosxxx.xxx ) and google it you can probably find another host.
Asus site is crap lately I cant get any bios updates my downloads keep timing out. is anyone else getting this problem?
Bios update utility
http://dlsvr03.asus.com/pub/ASUS/mb/flash/AWDFLASH119.zip
http://dlsvr01.asus.com/pub/ASUS/mb/flash/AWDFLASH119.zip
Bios version 0602
http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5N32-E SLI Plus/0602.zip
http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5N32-E SLI Plus/0602.zip
O just reread your post and yeah I cant seem to download any of them.
I updated my bios to the latest rev las night I finally got through but the temps still are about the same could my CPU really run that cool?
F*** knows... when i boot into xp in the morning my cpu reading is 15c and there no way my room temp can drop below 20c(usually 20-23c). You should be happy that your temps are low, although try to download all possible temps monitoring software and see how they differ
I am going to say they are real I have checked speedfan PC Probe and the Asus pmitor that comes with my MB all seem to idle in the mid teens. I ran the Nvidia system stress test for 3 hours and only got up to 30 degrees C. Thanks for all of the help now I am going to try some OC'ing to see what I can get out of it.
I started playing with my fans last night so the case didnt sound like a Jet engine and my temps are much more realistic.
I have Antec 120mm Tri cool case fan in front as intake I put that at 1520 rpm to quite it down
I have Thermaltake A2016 80 mmSmart case fan as Rear Exhaust its at 1896 rpm
Stock Side fan is not adjustable I will upgrade that later. I removed the cross bar on the case so that fan is gone.
I had to install the fan controller on my Zallman 9700 because I could not adjust the fan with the 3 pin MB conection. I adjusted it to 1240 RPM.
CPU temp is 20-25C idle and 35-40C under load
MB temp is stable at 33C
GPU idles at 45 and 50-55C under load
I have two questions I need a very quiet blue 80 MM fan to replace the side fan with a 3 pin MB conector so i can controll it with the asus software any recomendations?
Is there any way to have the Zalman 9700 be controlled by the MB without using the Fan controller that comes with it?
Isnt that what Qfan is for? or you can tick the automatic fan speeds box in Speedfan. or am i wrong
It is but I just found a post of why the Zalman wont adjust the 4th pin on the CPU Fan is for PWM and the Zalmann comes with a 3 pin connector. I either have to hook it up to a different fan channel on my MB and trick the bios into not alarming for CPU fan speed or keep the Fan mate installed which I might do. The 3 pin connectors on the MB can be controlled by the ASUS software but the CPU fan uses the fourth pin.
