Temp questions
Tony123
So just a while ago I found out about Motherboard Moniter and I thought it was cool.
I got a few questions though.
Are the BIOS temps displayed in MoboMoniter accurate?
Also id there a program that I can use to find the temps of my CPU?
I have an A8N SLI Premium
thanks for reading
MBM5 is as accurate as your sensors are, if the BIOS is right, it probably is too.
MBM5 should report your CPU temperature.
so Motherboard Moniter5 is the typical way that everyone gets their temp readings??
Some people don't like mbm just because of the fact that support for it has dropped and no more updates come out anymore. There are some other alternatives however
