I have been conducting a test of my system temps looping various graphic programs and playing demanding games, when time allows. I have logged some very interesting results.
First of all, this is my first AMD (FX-55) system so I wasn't quite sure what to expect as I have always used hot Intel chips.
The reason I chose water-cooling was because my NForce4 Chipset was running way too hot and I was getting the blue screen of death. My case was too small as well.
So after much advice form the very helpful people in this forum I took the plunge.
Most of you know my system so I won't go into that, but here are the results from my tests.
1. CPU-temps never fluctuate more than 3-4 degrees C, no matter what I do.
2. GPU's-temps fluctuate 5-7 degrees C for the first card and 3-4 for the second card.
3. NB-temps fluctuate dramatically, idle at 27 and then spike to-44, something has to be wrong here.
I use six temp sensors on my Aquaero and of course one flow sensor. The case temp only fluctuates 1 degree, if at all. If I OC the Aquasteam (65HZ) my XT drops 2 degrees within minutes, Shoggy said it would as did TN.
Since I am now the proud owner of 2 Aquastreams I am considering putting the NB on its own loop. Of course I may have a defective MB, but I have read much about the NB being very hot on these boards. Even the ASUS techs tell me the NB is way too hot on their boards, which is why they have (supposedly) upgraded the NB fan. I will say after water-cooling the NB my temps have dropped, but I still sense something smells fishy in Denmark. Any comments?
