temp diode question
bleed3r
I don't know if there is a temp diode on my MSI ti4200vtp
In that 3d!Something flash prog from msi, it said the temp was 32, the same as my case as it says in MBM, so I'm wondering if they are both the same, or one of them is acutaly the other. But I'm pretty sure the SN45G has a case temp sensor...
That 3D!whatever thing didn't even seem to change things when I clicked on them too, and they wouldn't change when I changed the clock etc. w coolbits.
Anyways, just wondering about the temps so I can be careful with the OC. Or would it not even matter, as long as it doesn't start getting weird in games and stuff then the temp should be fine?
