Is it ok to tape a Case Fan to the back of the case? (just want to know)
I would be hesitant to do it inside the case because if it happened to fall it might decide to eat something on the way down.
On the outside? Hey why not, tape is fun.![]()
So you are saying that it might fall and kill somthing?
well imagine what a fairly heavy object spinning at 2000-4000rpms falling onto a component in your computer could do.
Is there some reason you can't/don't want to just use fan screws??
Just curious
Dont want to spend any money. Becasue my old ones broke and i need something quick.
Um.. wow.
PM me your address and I'll send you a handful of fan screws... fast![]()
And, how on earth did you break fan screws?? Using the plastic type??
Um.. wow.
