System won't stay on
Dfresh
I just bought the components to build a new PC. Here's what I've got:
Asus A7V8X-MX SE (using onboard video right now)
Athlon XP 2600+ (333 FSB)
512MB PC2700 DDR
300W power supply
Every time I turn the system on it stays on for 1 second then turns off and then comes back on again for about 5 seconds and then turns off for good. Only way to get it to come back on is turning off all the power until the led on the mainboard goes off. When I give it power again it does the same thing. Sometimes I get some video, but there's no errors I can see before it shuts off.
I've tried 3 different power supplies 250W-400W, an Athlon XP 1700+ from my other PC, and a different stick of 512MB PC2100 DDR. I've even disconnected all the cables for the case leds and switches. Does anyone know if there's a specific setting for the dip switches or a jumper that I'm just missing? Any suggestions are appreciated. Thanks
make sure you dont have anything cought between the heatsink and cpu socket.mine was doing the same thing and a fan wire had been caught under my water block and the socket cam shoulder
This is really weird. I tried it again today and got the video to stay up long enough to see that I'm getting CMOS checksum errors. Then, after playing around with it I got it to start & stay running once with it outside the case and nothing but CPU, RAM, & onboard video. I went into the BIOS and made all the changes then turned it off and it just turns on for 1 second then turns off again. I tried the CPU in a different system and it did the same thing. So I think I'm gonna RMA the CPU first.
CMOS checksum errors are normal- sounds like a heatsink may be on backwards or you may be lacking thermal grease.
it doesnt really sound like this but who knows.:
i had an abit board that when i was first putting the computer together did the same thing, it would come up and cut off in like 1 or 2 seconds.
turns out that the motherboard had a built in RPM censor for the MB fan, and if it detected no RPMs from the fan the MB would shut down. and i had a non-standard fan with molex power so it detected no RPMs (it detected through fan power 1) after attatching a plug to connect to fan power 1 i no longer had this issue.
