System Won't Boot. Suspected video card problem!
simon741
Hello,
Last night my computer was fine. I downloaded the Cell Factor demo and drivers, and used the command line to add to the shortcut to be able to play without the PhysX card installed in your system. Well, I played for awhile and everything was fine. I stopped, went back to desktop, and still everything was fine. I turned the computer off, and now when I go to turn it on, it gives me one long beep and two short beeps. I'm assuming this is a video card problem. The monitor will turn on, but nothing will show up on screen. It is like its not getting a signal or something, and I can't test using onboard video. My mobo doesn't have it.
Amd 3500+
A8n Sli
6600gt
200gb Maxtor
SB Audigy 2zs
Thanks and any help will be much appreciated. I hope my PC isn't screwed.
Probably.
You can always go to Wal MarX( :) ) and buy a cheapo pci-e card and see if you can get something to work. That way you either ensure or eliminate a video problem. Oh, and if it is the video problem you could just keep the card to tide you over until you get another or whatever, and if not, you can always take it back.
Well, the thing is that the computer won't show any display or anything so I cant keep using it. I don't really want to buy a new video card, because the new 8600s and stuff are coming out, but then I cant game. I'm kinda stuck in a pickle here. How much do those cheapo PCI cards at wal mart cost?
One long beep and two short beeps means "RAM Failure".
Try moving your RAM chips around to alternative slots. If that fails, try removing one and running with one stick of RAM.
I googled this and every spot I looked said one lone beep and two short beeps was video related...
It usually is. Have you tried re-seating and cleaning your card? Make sure that the fan is clean. You might also want to try a different monitor cable just for fun.
I tried a different monitor and it didn't work. I am in the process of removing the card and putting some old ass ATI RAGE card, just to see if it is video related or not. Thanks for the ram idea, I'll try it out. You never know i guess.
Alright, well the RAGE card was I think AGP while I thought it was PCI. I put together a little p3 rig together so I can use something as a computer. Still, the long beep then the two short ones. Ima call evga and see what they can do. I cant believe that playing Cell Factor did this. WTF!!!???
