System Will Not Boot?
robertw477
Having ongoing problems with an Acer Quad Core system at work (3 yr old machine). System did not want to boot. It was locked on BIOS. Went through normal procedures and felt crummy 250W power supply was probably DOA. Replaced the power supply with a 400W. Initially I booted windows 7 and everything seemed fine. The next day on boot it makes a long beep/screech sound and as it starts to run windows, it turns right off. Any ideas what might be the issue. The graphics card should be fine but we also have onboard graphics to check. Didnt matter same issue. I appreciate any ideas.
Robert
Read through the Basic Troubleshooting Guide for when your system won't post. Post back your results! Also post your full system specs or the model of your Acer (also include the make/model of the power supply you put in there).
