System hangs when I try to install something.
Stardusted
I have a P5K (vanilla) a q6600 4gb of ram (2 x 2gb g.skill 6-6-6-18) 2 x WD 80gbs hdd and one 250gbs WD SATA hdd.
Problem is... I have installed windows xp sp2. Run prime95 for 9 hours, all ok. Run memtest for 10 hours, all ok. System appears to be fine, I can run programs copy files from one hdd to another.
Then I try to install colin mcrae dirt... it hangs at the same file mid-installation all the time, every time. Most of the times it simply stops at that file doing nothing, and even though I can move the mouse pointer I can't click anywhere. Once it stopped again at the same file, but gave me a blue screen instead.
The game disc is fine I double checked at a friend's, and I also know so cause I have installed it and never had problems on my old computer, on which I used the exact same hddrives.
I even took out my SATA LG dvdr and plugged it on the friend's computer, it installed fine once again. I even made a virtual disc image of the game and installed it that way, straight from the hard disk. Again fails at the same file, and again it installs fine on other computers.
That's the second xp installation I do on this new system. on the first one I was getting jerky mouse movements cpu spikes (around 30% usage) and whenever I run one specific exe file from a specific directory (coretemp) the system reseted.
...WTF ? haunted ?
I have even waited for 3 hours, it is not working. I can't even open up task manager, do nothing.
EDIT : It just gave the blue screen once again, it reads at the start of it :
"A problem has been detected and windows has been shut down to prevent damage to your computer
A process or thread crucial to system operation has unexpectedly exited or been terminated"
and at the bottom it says
"Begining dump of physical memory"
UPDATE : When I made an image of the game disc, I tried to run the installation from the SATA drive and install to an IDE drive (tried both). Crash. Next I copy the installation to IDE drive and try to install on the other and the same IDE drive. Crash.
Now I copied the installation to the SATA drive and tried to install on the SATA drive. It installed fine :S.... IDE problem ? Both IDE drives worked great on my older pc.
I would take everything apart and reconstruct the system from the ground up. Odd problems like that could occur from a CPU seating issue. Also, I would try testing your memory one stick at a time and see what kind of results you get. You might also look for a BIOS update for your machine. Finally, (although given that you did reinstall I don't think this is it) you could reinstall the windows installer - it might be gummed up.
