The Problem:
Temporary system freeze with audio stutter. The system recovers 30sec - 2min later.
Key presses made during freeze will execute after system recovers (ctrl+alt+delete for example)
Usually, but not always, I see an error message in the system tray and I do NOT experience bsod.
This happens seemingly at random from 3D accelerated applications, and web browsing. Games such as BF3 (moderate), WoW (seldom), Planetside 2 (frequently), Minecraft (seldom), Hawken (seldom), etc.
Also happens frequently in both Internet Explorer 9/10, Firefox, Chrome, and Steam store browser. Typically when watching steaming video (youtube, HULU, flow player, etc)
but Pandora audio streaming also seems to create the conditions where this happens.
Error Message:
"Display driver stopped responding and has recovered
Display driver NVIDIA Windows Kernal Mode Driver 314.07 stopped
responding and has successfully recovered"
The problem also shows up in the Windows reliability history with the following data:
Source
Windows
Summary
Video hardware error
Date
‎3/‎6/‎2013 9:11 PM
Status
Not reported
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Files that help describe the problem
WD-20130306-2010.dmp
sysdata.xml
WERInternalMetadata.xml
Extra information about the problem
BCCode: 117
BCP1: FFFFFA8011E0C4E0
BCP2: FFFFF8800654A198
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
My System Hardware:
CPU: Intel i7 2600k @ 4.5ghz
Motherboard: MSI p67a-gd65 (B3 stepping)
Memory: G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
GPU: Originally MSI 6950 2GB. Replaced with EVGA 670 FTW 2GB.
PSU: CORSAIR HX Series HX850 850W
HDD: 3x Western Digital WD RE4 WD5003ABYX 500GB in Raid 0
OS: Windows 7 Home Premium SP1 with all updates
Case/Cooling: Silverstone Raven 2E with Thermalright silver arrow cpu heatsink
What I've tried:
Updated all motherboard drivers and bios (4.3) to current versions (no improvement)
Updated display drivers (in safe mode with driver sweeper. No improvement)
Updated Realtek Audio drivers for onboard sound (no improvement)
Updated Intel Rapid Storage drivers (no improvment)
Cleared CMOS and tested system at default settings with no overlock (no improvement)
Flashed 6950 back to 6950 stock bios and removed overclock (no improvement)
Replaced old 6950 with new GTX 670 (problem still occurs in the same exact way)
Tried GPU in 2nd PCIe slot. No improvement.
Checked GPU Temps. GTX 670 fan profile in EVGA Precision X set to keep temp below 70 degrees Celcius. Card maxes at 60 degrees under heavy gaming load.
Complete reformat of raid array with fresh install of Windows (4 different times) Seemed to help for a few days, then freezes came back
Ran OCCT and Prime 95 Torture tests separately for a few hours at stock and OC settings. System stable with core temps of high 50's overclocked, and low 40's stock.
Ran Memtest86 for 10 hours with zero errors.
Used digital multimeter to test 12v rail on PSU. Noted solid 12v reported. Didn't test other rails.
Unplugged PSU cables from motherboard and reattached firmly
Ran HD Tune and Data Life Guard Tools for error checking on hard disks. Zero errors found.
Disabled Windows Aero (no improvement)
Updated Adobe Flash Player to latest setting (no improvement)
Removed Adobe Flash Player (no improvement)
Turned off Adobe Flash hardware acceleration (no improvement)
*EDIT: Forgot that I also adjusted Nvidia driver profiles for apps that have frozen to include power preference to max performance
All of my hardware with the exception of the new 670 was purchased and configured back in February of 2011. This problem first occured in BF3 multiplayer sometime in early 2012,
and has gradually been happening more frequently. Web searches found many individuals with this error, but the solutions are all over the map, and I've tried just about everything that I've found.
I think I've narrowed the problem down to the motherboard, but I just can't find a clear answer or solution. Maybe it's the raid array? I really thought replacing the GPU would solve my trouble here
and I was...NOT happy when it happened again with the new 670 that I scored for $250 after amazon gift cards. I typically get kicked/disconnected during online game play when this happens and I'm ready to be done with it. I was hoping to fix the issue without needing to buy new hardware, but I don't see any other way at this point.
My patience runs thin. Please help!
Error Message:
Source
Windows
Summary
Date
‎3/‎6/‎2013 9:11 PM
Status
Not reported
Description
Problem signature
Locale ID: 1033
sysdata.xml
BCCode: 117
Service Pack: 1_0
Product: 768_1
My System Hardware:
What I've tried:
