I need help with choosing components...
I already have: 2 x WD3000JDRTL (to set up raid mirror)
old CD drive (should still work with newer systems right?)
10 x MASSCOOL FD08025S1M4 80mm Sleeve Case Fan
couple of old(5-10 yr) ethernet cards
With a budget of $500, I would like to build a system around possibly this:
Intel Pentium 4 630 w/ HT Technology - 3.0GHz Processor Retail
(3.0GHz, 2MB, 800MHz FSB, Socket 775 - SKU: BX80547PG3000F)
for $185
so that would leave me $315 for:
1 case (possibly antec sonata II??)
1 psu (not needed if case has a sufficient one)
1 motherboard (ABIT AG8 ?)
1 cheap video card or intergrated is fine
1 GB RAM
possibly get oem CPU then buy separate heatsink/fan?
Other wiring or parts I'm missing?
As you can see, I don't need bells and whistles, I just need a decent and reliable system to use as a server. I prefer a black case with room to work with since this will be my first complete build. No need for fancy graphic/sound. Is this possible or can you guys come up with something that even costs less? I'm not stuck on that CPU so if you guys see something that's a better value, please chime in. What's the best bang for $500 bucks or possibly under? I need this asap so please, if you have something to say, don't save it. Thank you for your valuable time.
for $185
1 GB RAM
