roninblade
- Sep 22, 2004
I got my 941BW and i cant get the 1440x990 resolution on it. What do I do. Also whats that good program for dual displays. Thanks
freakycody said:put your refresh rate to 60hz. DVI cable is only spec'ed at 60hz when running the native resolution.
freakycody said:vgam will not be bad..... that sucsk u can;t use dvi..... call up samsung and say what gives
also you should be able to use dual monitors with yoru stock vid card drivers... i can use dual monitors on my pc with just the regular ATI drivers.
