SX 830 front bezel
Gorankar
I have been looking for a black, Antec SX 830 or pretty much any black SX 800 series front bezel with no luck.. Found black side panels doors' and feet but no complete bezels.. Any one know where I could buy one of these things?.. Antec no longer carries them.. I would rather not paint the bezel if I don't have to..
If I can come up with a front bezel all, I will have to paint is the top of the case and the thin strip of metal on the sides below the doors..
Any help would be appreciated.. Thx
I have had a SX840 before I purchased my lian li. As far as I know, there are no black SX830/840. This was the "performance" series and then Antec introduced the "performance II" series with black model. The 600 and 1000 were available in black and if I do remind correctly, the Perf. II in the 800 was not. I do know that the bezel is a bit different from the Perf. to Perf. II but I don't know if they are exchangable.
Para
Thx for the reply.. The 830 and 840 front bezels and sidepanels are interchangeable according to an e-mail I got from Antec when I queried them on this subject.. They had side panels, and feet of all things, but no front bezels.. It was worth a try.. If I can't find one by next weekend I'll just paint what I have.. Maybe I'll go with a dark charchoal instead of black, since I'll have to paint it all anyway.. Aww screw it, I'm just going to buy a Lian-Li 1200B and be done with it.
