Switches for case lights.
NKDietrich
So, I need a couple switches to turn cathodes on and off. I'm not really sure what the cheap option is that doesn't require me to solder things or drill holes.
Ideally here's what I would like, though I understand if there's no perfect solution:
5.25" Bay.
2+ On/Off Switches (no rheostat or 3 position switches)
Sleeved and Molex'd.
With either no LEDs or white LEDs.
Preferably not $50-100 bucks as some websites seem to think this sort of thing is worth.
I'm not completely averse to taking out the hole saw to one of my front panel inserts if I have to, I guess!
Two of these.
Sleeved rockers
But they will require you to drill the holes in your 5.25 bay covers. You can find cheap rockers elseware and wire your own, but will require some soldering, unless you can find screw terminals.
I prefer these. But again will require some self wiring, unless you want to pay double for sleaved and molexed.
Vandal latching switch
If you really are just unable to drill holes, you can get these for a ridiculous price given what they are.
Switch Plate
Shop around you can find more of the same at FrozenCpu, Jabtech, etc.
