I am currently at stock speeds, rig in my sig, I am orthos stable 8 hours, I am memtest stable, I open up two instances of SuperPI and set the affinity of one to cpu0 and the affinity of the other to cpu1, I try to run both but every time I almost instantly get an error on whichever core I start the calculations on second. If I run two instances and set the affinity on both to use both cpu 1 and 0, I get an error from one right away again. If I just run one instance everything works fine. I first noticed this when I was overclocking and I noticed the SuperPI errors so I set it back to stock speeds and same thing. Is this normal or is something wrong?
