Suggestions for building first system
Daltry23
I am looking into building my first system for around 2,000 give or take a couple of hundred. Here is what I'm planning on building, I was wondering if anyone has any tips, suggestions, or if I'm overlooking something. I feel pretty confident about my processor, video card (plan on going sli in 1-2 years when it is actually worth it), hard drive, and dvd burner. My biggest concerns are getting a decent psu, case, and memory.
Processor: Athlon 64 x2 4400
Motherboard: Asus A8n-sli Premium socket 939
Graphics: BFG Geforce 7800 gtx
Hard Drive: Western Digital Caviar SE 300GB 7200 RPM IDE Ultra ATA100
Burner: NEC 3540A
Case: Thermaltake Tsunami VA3000BWA Black Aluminum ATX Mid Tower
Power Supply: Thermaltake PurePower W0023R ATX 560W
Memory: 2 CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200)
This all comes to a total of a little under 2 grand. Thanks for any suggestions!
Looks like a solid build. Only thing I would change is the power supply (maybe an OCZ powerstream) and some better RAM. Otherwise everything looks good.
If you're not going to overclock, the Corsair VS will be excellent. Your HDD could use an improvement, however... That's gonna be a BIG bottleneck with the other specs. Look into the Raptors (for blazing speed) or the new Maxtor SATA II 16mb cache drive (for good speed AND storage).
I read SATA hard drives are more difficult to install for beginners. I've also seen messages from people on the Anandtech technical support forum saying they had problems with their 3540. I got a 3520 and had no problems except the fact Roxio 5 would not burn a DVD. However, Nero was able to.
Where u read dat? If you can install a PATA, you can install a SATA. You plug in power, you plug in data. Stinkin' simple, man.
Well I don't really plan on doing too much overclocking, so I'm glad to hear that that RAM should work well. If that HD will work a lot better, it's around the same price, and I have a friend that's built several computers if I should need help, but I think i'll be fine.
i think he meant the drivers
Yah, Windows installation can be a pain...just get a floppy drive and the drivers from your motherboard's website and put em on a floppy.
