Suggestions: about to order
cb9fl
I'm about to order a replacement for my aging Athlon XP 1900+.
Here's a rundown of what I'm about to order and I welcome suggestions.
ASUS P5W DH Deluxe/WIFI-AP
Intel Core 2 Duo E6600
Corsair XMS2 2x1GB (PC 6400) 5-5-5-18
eVGA GeForce 8800GTS
ENERMAX Liberty ELT500AWT
I decided on the E6600 for an easier modest OC to high speeds. 8800GTS since I don't want to spend the extra $200 for the GTX. How does everything else look?
skip the enermax liberty, zzf has the corsair hx 520 for $106 shipped. much better supply.
Crossfire board with an nVIDIA GPU? If you want SLI, go for an nForce 680i or 650i SLI board instead. If you don't need SLI or Crossfire, then go for the P5B-E or DS3, which would save you quite a bit of money. Go for some Buffalo Firestix if you want the micron ICs. If not, then some cheap g.skills will do just fine. I agree with Bbq on the PSU.
From what I've read that board offers better overclocking options for the E6600.
I think what you have is fine. With the 9x multiplier you don't need some crazy FSB speeds to max out your processor. As mentioned above that PSU deal looks nice but I like your setup.
