Sub $200 22-24" LCDs
Feel free to nominate your own suggestions if you've got better candidates!
Dell 2209WA 22" the best option(E-IPS) good viewing angles low gamma shift
decent input lag,good colors 200-230 $ add great support on the list also.
It destroy every TN monitor you got amazing deal.
Can you show me where I can buy one for $200? I'm not even sure you can find em in stock. Hmm and it looks like they only have 1680x1050 resolution...
AOC 2217V 22" 1680x1050, got it for about $180.00
I'm having a hard time deciding. Nearly all the sub 200 dollar monitors have their warts. And most of them are not adjustable at all. :(
What in the world happened to adjustable stands??
What do you mean by adjustable stands? I thought tilt was standard.
My Samsung monitor has height adjustment, swivel, and rotate. Tilting isn't the only way to adjust a monitor. Oh and it also can turn 90 degrees so i can look at long documents. You've never seen a truly adjustable monitor before or are all new monitors lacking these ergonomic functions?
