Hi all,
I just finished building a system with a Gigabyte GA-P35-DS3P (Q6600, 2x2Gb DDR2 800, eVGA 8600GTS, Corsair 620HX). It seems to work fine, based on the observation that it boots a livecd of Knoppix and is fully functional. A strange problem though: Immediately when I turn it on, before even I get any display I get a disconcerting beep (one burst, much lower in pitch than any beepcode) from the PC speaker. Then the display comes up, it displays the amount of RAM installed .etc and gives one straight beep to indicate everything is normal. I can't find anything in the motherboard manual that talks about what that could mean, although the manual is pretty useless when it comes to troubleshooting. Any ideas?
Thanks,
-Ben
Thanks,
-Ben
