http://windows.about.com/library/tips/bltip610.htm said:Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
Data Type: REG_DWORD
Value: 0
No registry hacks required for that. Just go into your Security Center, select each of the different things that are giving you popups, turn them off, and in the bubble that pops up, click and select that you have your own solution and do not require Windows to monitor it. It's really that simple.shefron said:How do you stop the little info stuff that pop ups in xp that gives tips. Like the one after sp2 update that warns about no virus stuff and how autoupdate is off.
shefron said:Thank you for the info other then the smartass remark. Google sometimes works nice if you put in the right statement. Believe me I did google it and screw around for a bit on my computer but just had no luck finding it.
GreNME said:No registry hacks required for that. Just go into your Security Center, select each of the different things that are giving you popups, turn them off, and in the bubble that pops up, click and select that you have your own solution and do not require Windows to monitor it. It's really that simple.
