Stealth
vage
I want to stealth my cd drive and possibly my floppy-drive(if possible) on my SK83G. I have seen a lot of threads for it in many other forums but they are all kind of old and the pictures won't load on them anymore. I was wondering if anyone here has any good tutorials with pictures because I like to have something to reference to make sure I am doing it right.
I can't seem to find anything on that site that has to do with stealthing a shuttle optical drive. Anyone else have any links or anything?
I've stealthed mine, but I don't got any pictures atm. I iused double sided sticky tape, removed the orginal drive plate cover, pushed the drive back and then took apart the Shuttle cover and stuck it to the drive plate. Simple as that
Heres one way of doing it though double sided tape will work much better like I used.
Shuttle Stealthing
THANKS!!! that is a huge help. I will also use the double sided tape but now that I can see what I have to take off and put where and everything it makes it a lot easier.
