Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
hey im just starting with the whole modding thing is there anything i should know before i start. I would like to mod my PS2 and eventually my computer case. does anybody have any suggestions or anything.
get a dremel and just get started. when i first started, i was afraid of cutting up my case, but it turned out to be much easier than i had originally thought. get some experience as soon as you can
Get your basic tools such as a Dremel, jigsaw drill and drill bits. Make sure you have a good tape measure and rule also. Plan ahead and remember to measure 2-5 times and cut only once. Have fun and enjoy what you are doing.
