stanford problem?
Posidon42
I was just given a 11061 project but the F@H client seems to be hung. The status is "Update_Core". The log file says:
*********************** Log Started 2012-10-18T15:52:01Z ***********************
15:52:02:ERROR:WU01:FS00:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
15:53:02:ERROR:WU01:FS00:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
15:54:39:ERROR:WU01:FS00:Exception: Failed to connect to www.stanford.edu:80: The requested address is not valid in its context.
Thoughts??
To me it looks like borked state in the client itself.
Did you try completely shutting the client down and restarting it?
you did not happen to change the client name from local did you.
nope. It was working just fine until this morning when it finished the WU and went to get another one. Then this started happening. It is still borked.
Code:
02:36:04:Trying to access database...
02:36:04:Successfully acquired database lock
02:36:04:Enabled folding slot 00: READY smp:4
02:36:04:WU01:FS00:Downloading core from [url]http://www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah[/url]
02:36:04:WU01:FS00:Connecting to [url]www.stanford.edu:80[/url]
02:36:04:ERROR:WU01:FS00:Exception: Failed to connect to [url]www.stanford.edu:80:[/url] The requested address is not valid in its context.
02:36:06:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
02:37:04:WU01:FS00:Downloading core from [url]http://www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah[/url]
02:37:04:WU01:FS00:Connecting to [url]www.stanford.edu:80[/url]
02:37:04:ERROR:WU01:FS00:Exception: Failed to connect to [url]www.stanford.edu:80:[/url] The requested address is not valid in its context.
Strange stuff going on here and it just keeps trying to update the core. Lost an entire day's worth of production.
disabling ipv6 did the trick, but I don't like doing this... Let's hope they find a way to fix it that doesn't impact the donor network security.
