Some advice please..
I'm currently running vmWare workstation on a Core 2 Duo (12 GB RAM) laptop with 256 GB SSD.
I'm running 4 Windows Server 2008 R2 VMs that are used to build images (additional VMs) for deployment. These four servers include:
The problem I'm having is that when I spin up a couple of image builds (new VMs), it just way too slow (CPU is pegged). I'm thinking that an ESXi build might solve this problem. I've run this configuration on our production Hosts (Dell R710's) using the internal 15K SAS drives and although it comsumes a lot of CPU, it flies in comparison to it running on my laptop. I really don't want to run this in production, but need more horsepower.
Here is my planned configuration:
I know this build doesn't have all the storage isolation, HA, VMotion goodies, but I need a fast machine to plow through the build of deployment images. The image deployment process moves a ton of data, hense the SSD. Once this project is done, I'll add the machine to our SAN and use it to dev / test new Production VMs.
The problem I've having is deciding on the above motherboard or switching to one that will allow me to up the memory to 32 GB (SuperMicro MBD-X8SIL-F-O). From my research the 2 x 8GB Kingston memory will not be available until at least May..
and is way overpriced.
Has anyone compared these two motherboards?
Thanks for your advice / help.
SQL Server 2008
Active Directory, DHCP, DNS, Etc
Deployment Server -- Microsoft Deployment Toolkit, Windows Deployment Services
Gateway -- Internet Access, otherwise other VMs are on internal Host only network
1 - LIAN LI PC-V352B Black Aluminum MicroATX - want micro ATX for portablity
1 - SUPERMICRO MBD-X9SCM-F-O LGA 1155 Intel C204 Micro ATX Intel Xeon E3 Server Motherboard
2 - Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1333 (PC3 10600) Server Memory Model KVR1333D3E9SK2/8G
1 - SeaSonic M12II 520 Bronze 520W ATX12V v2.3 / EPS 12V v2.91
1 - Intel Xeon E3-1270 Sandy Bridge 3.4GHz LGA 1155 80W Quad-Core Server Processor
1 - Crucial M4 CT512M4SSD2BAA 2.5" 512GB SATA III MLC Internal Solid State Drive (SSD)
1 - Verbatim TUFF-'N'-TINY 4GB Flash Drive (USB2.0 Portable) Model 96815
1 - Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM SATA 6.0Gb/s
