Stackers: 810 vs. STC-T01
Seufari
So I am just starting to research high dollar cases, and am interested in The CM Stacker. My questions regard the difference between the 810 and the STC-T01.
1) Which is newer?
2) Which is generally perfered and why?
3) What are the differences?
4) Which has a better resale value?
So yeah... If anyone has anything they'd like to add please post...
Thanks
No question the Stacker 810. More rear exhast fans and a much better PSU location if your psu pulls air from the bottom. It is also better for water cooling. Dual 120MM rad anyone?
How does the 810 have better PSU location as the T-01 has dual PSU bays?
Because they make the process easier for you by only allowing you to install the PSU into the optimal location :p
Mainly Dual 120MM for the win!
The original (STC-T01) is, IMO, still the best all-around case for the money- especially if watercooling is in the picture.
Also IMO...computer cases really have no "resale" value- certainly not enough of one to base a buying decision on.
I have the 810 and I would highly recommend it to anyone. I like the dual 120s on the back. My only gripe is that the side grill should allow for different configurations of fans, not just the single small one in the middle.
