Stacker-like case
LstBrunnenG
I've recently decided to move my four-drive RAID array into my primary desktop, which is a P180. Unfortunately, the computer also has a GTX 280, which is too long to allow me to use my primary hard drive in the upper drive cage. Right now it's sitting loose on the lower 5" bay.
Combine this with the fact that the power cables for the drives keep curving back into the fan blades of the lower-chamber fan, and that I may eventually want to grow the array, I've started thinking about a new case.
An ideal case would be one of the old CM Stacker cases. Unfortunately, it doesn't look like they make those anymore. Closest analog I could find was the Antec Twelve Hundred.
Any other suggestions? Needs lots of hard disk bays, plenty of length for large graphics cards like the 280 or a 5870, and needs to have adequate cooling.
Sharkoon Rebel 12
guess there will be an update soon on Rebel 12, Rebel 9 already has been updated.
But i'm not 100% sure with the graphics card, you have to check
