TechonNapkins
- Oct 20, 2010
[SCROLL DOWN TO THE BOTTOM OF THIS POST IF YOU WANT TO SKIP THE BACKSTORY AND JUST GET THE QUESTION OF THIS THREAD]
I put "speedstep" in quotations because it applies not only to Intel, but also AMD (both CPUs and GPUs) and Nvidia as well... I guess "clock profiles" would be more accurate, but I digress...
For the last few generations of CPUs and GPUs, I've noticed stability testing has become much more laborious and uncertain. It used to be you could run Prime95 or Intel Burn Test overnight and, if no errors, you could safely assume the system was stable. And if your GPU could withstand Furmark? Oh, done deal!
Well, the last time I remember than being the case was with my Core2Duo E8500. It all changed with my Thuban 1055T. Everyone was claiming 4GHz was a no brainer...
... a no brainer? Well, call me brainless, 'cause unless I pumped over 1.5V into that thing, I couldn't even boot into Windows at that speed. And running Burn Test for just 20 minutes at that speed I noticed the room temperature rise significantly. I stress tested it close to 3.8GHz at reasonable volts, but I would eventually run into odd crashes every so often. Backing it off to 3.7GHz eventually stabilized the system.
Early this year, I jumped on the 2500K bandwagon, and again, 5GHz was supposed to be "brain-dead-easy". Not for me it wasn't. I could stress test it at 4.6GHz, but I had to bump it down to 4.4GHz for day-to-day apps.
Then there's my recent GTX570 purchase... I can run Furmark for five minutes with no issue at 880 core, but can't play for 5 seconds without crashing in Just Cause 2.
What's going on here? Why would an app that stresses all cores at 100% show stability, yet a much more lightweight app eventually initiate a crash? I believe it's in the power/clock management. In a current CPU/GPU, the clocks and volts are bouncing all over the place to cope with demand. There's the "Load-Line Calibration" feature we can tweak to try to stabilize the voltage, but at the expense of exposing our CPUs to higher power spikes. I remember one guy with his Thuban made a custom profile for every clock stepping to ensure stability at any load.
I suppose an easy way out of this predicament is to go backwards - disable all the power saving features, set Load Line Calibration to high, and force a singular clock rate - and indeed, that is what many extreme overclockers have done... but what about us normal folk? I, for one, find a home PC idling over 200W to be unacceptable. I want to keep these power saving measures in place, and I'm sure many of you guys do too. So, how to we test overclocking within this new paradigm?
In short: what are the apps you've found that expose instability that others have failed to expose? CPUs or GPUs.
