SSD for OS ?
Simmonz
Would it be a good idea to put your OS on a SSD or SSD RAID and my files on an SATA II HDD ? Would there be an increase in speed ? Money isn't a concern.
i dont know if this has changed at all, but i remember reading somewhere that SSD's have a max amount you can write and rewrite to them. This was quite some time ago, not sure if they have fixed that problem or not.
SSD will make a huge difference in your computing experience.
If money is not a concern you should just get the intel x-25m 80GB for $366 at newegg and be done.
You can also get the OCZ vertex to save some money, but it can require a bit of tinkering to get everything working perfectly.
Read this article:
http://www.anandtech.com/storage/showdoc.aspx?i=3531
