SSD 3.5" adapter question
Auraka
This is probably asking a lot, but does anyone know if the adapter supplied by Intel (in retail SSD package) or SilverStones 3.5" adapter will correctly align the SATA and power connecters so that the SSD can be used with a backplane in a SuperMicro removable tray? My case is a CSE-733T and my mix would be two 3.5" WD1001FALS and the SSD as boot/op drive. Using the tray/adpater would be ideal for now.
The Silverstone adapter will not align the SATA connector to the same place as a 3.5" HDD. I do not think the Intel one will, either. It would involve mounting the SSD off-center...in fact, I think almost all the way to the side of the adapter.
I figured as much, on to plan B (and figuring out what B is). Thanks for the response.
Are there no mounting holes on the bottom of the caddy for 2.5"? If not, you can ask SuperMicro if they have an adapter. If not, then you can always take a drill to the caddy. :p
The caddy is composed of side rails and a front, nothing more. The 3.5" drive itself is the bulk of the caddy structure once assembled.
The Icy Dock MB882SP-1S-2B Converter might just be the ticket though I'm not big on plastic. Thanks.
Agree about the plastic part, but it does work fairly well and is about the best solution I have found so far. The 1B version does have metal on the inside and might be better.
