Split Level Cases
monkstah
I can't remember what they are called, but what are some good split level cases... the kind where the PSU is on bottom and you can weave cables up to the Mobo area....
Thanks in advance.
Lian Li V1000, V1200, and V2000 series.
Expensive, but the best case that I have ever owned.
Performance-PC's will do some pretty good mods to them as well
I am quite concerned as to why no one has said this yet - but the poster is asking about cases where the psu is in a SEPARATED AREA - not one open case like the silverstone - cases like the Antec P180 and the like.
there ya go.... what are some good cases where the psu is located separately... i've seen photos where it's the psu and a hard drive rack on the bottom, and then the externals and the mobo on top with the hole for the cables to go through.....
i can't remember any cases like it off hand though.. and am looking for a couple good ones to possibly look at.
the lian li's mentioned are kinda what i'm looking for... but cheaper.
P180 is what you're looking for.
Thermaltake Mozart TX (if you don't mind another piece of furniture in the room).
I have the Mozart TX...huge but with 4 thermal zones, and surprisingly lightweight.
Excellent airflow.
Silverstone st-07
LianLi
v2000 (v201, ect)
v1000
Antec p180 (p190 soon)
I know i repeated some of them, but it is much easier to just list the one's i can remember
