Aug 30, 2007 #1 S Suds Limp Gawd Joined Jul 24, 2007 Messages 352 Just a quick question. Speedfan shows my CPU Temp at 46C yet the cores are at 36C and 37C. Why is there such a jump between Core temps and CPU Temps. BTW, it's an E6600.
Aug 30, 2007 #2 S Suds Limp Gawd Joined Jul 24, 2007 Messages 352 Also, what should the MCP Temperature be on the 680i? I just got my RMA back and I used to run it fanless. I just want to see if the temps good.
Aug 31, 2007 #3 Z zmjone2992 [H]ard|Gawd Joined Jul 3, 2007 Messages 1,033 it is your cpu die temp, vs. the core temp diodes inside. They are going to be hotter always. Don't know about the nforce chipset....
